'65 CB160 "Ghost" Update
Dialed in and rode der Geist home today. 16 miles. Flawless. Too many thumbs up, shakas, call outs, and other ride acknowledgements to count. Had one group of young ladies (college age?) tell me, "That's hot!" as I sat idling at a red light.
I felt like my left hand was only sometimes on the bars responding to the fan base acolades.
I also picked up a "time period" helmet. Now I look like a lollipop-head riding along; or the robot from Hitchhikers Guide to the Galaxy - you make the call. :LOL:
So much fun riding a vintage Honda twin. 🏍️❤️
A funny thing happened on the way to the forum...
Yesterday was a perfect day to be out and about on a bike (~70F and sunny), so I went for an extended ride. Less then a mile from home on the return trip old Ghost started making excessive noise. I of course pulled off and started looking the old gal over, and... found that the front right exhaust was nearly detached; nuts and washers nowhere to be found.
Upon further investigation I also found that the interior mounting stud was completely stripped mainly due to the PO's hack-job attempt to address an earlier issue.
Now I'm not a trained and certified machinist - but I have stayed at a Holiday Inn and Suites - so I drilled, tapped, and Helicoil'ed the offending stud hole, and then fabricated and installed a new (albeit 8x1.25) SS stud from a Lowe's Hardware 40mm SS bolt.
All back together again, Ghost is resting-up post surgery and looking forward to the next outing. Having just addressed her derrière, however, I'm hopeful that the next outing won't include a cycle-hip or -shoulder replacement...
Vintage cycles are a constant labor of love, aren't they? That is all. :rolleyes::LOL:
Not that I know if it makes any difference, the factory setup and as described by the parts manual is there are no washers under the exhaust flange nuts
I'm seeing them in the CB160 fiche on CMSNL and it certainly seems prudent to use them given what happened.
Interestingly, 14 is shown as the spring washer and 13 is shown as the nut. <JOKE> That would certainly explain how they ended up on the side of the road. </JOKE>
You beat me to it!
Correct you are. I was looking at the CL160 fiche, apparently "offroad" bikes don't need no stinkin' washers
Been there, done that. 👍
It occurred to me after I asked that one nut on each header would probably be enough for that one mile ride. (Assuming you had tools to move one to the other header.)
Solid call! It would've got me home, 4sure. In the end I've added a couple nuts (6 and 8) to my onboard "bag of tricks".
However, with all of the extras in that little sack someone might go and call me Hermione Granger. I think if I looked long enough I may have a spare cycle in there tucked away in some library cubby...
I seem to be filtering down through the various potential issues when bringing a vintage twin back to 'street ready'.
In today's edition: Front tire blow-out
Riding yesterday I heard a definitive *pop* followed by the front end of the biking destabilizing rapidly as I fought for control whilst decelerating as fast as possible. Coming to a complete stop - with a redlining heart rate - I hopped off the bike and discovered that the tire liner was partially laying out of the tire, which was completely deflated.
I went from full-up tires that I'd checked when grabbing gas earlier in the ride to a blown-out, deflated in less than a second at nearly 40 mph, front tire. No bene...
New tires are ordered - and new undershorts as well. 😬
I'm glad that you were able to stop safely, that would be scary for sure.
Is there any indication of the cause? Tire pressure? Are any of the spokes protruding very far? Did the rim strip have any holes?
Front tire pressure was just a bit low - only a few lbs psi - when I'd filled up earlier. I corrected that then and verified the rear pressure. Nothing on the tire's exterior tells the tale.
Tue I'll load her up and take her to the shop to remove both rims for our local cycle shop. I prefer them to re-shoe, spoke check, and balance. Hopefully I can track down the cause then.
