Removing old tank liner?
The Lloyd
Edmonton, Alberta
i picked up some project bikes, in fairly decent shape for the price $800 CDN, for a 74’ CB125S, 77’ CT125 and a 74’ XL125 parts bike.
All three have tanks in decent shape, great paint, no leaks or rust. But All Three have liners in them, the XL and CT are in good shape but the CB tanks liner is peeling and needs removing.
i am 99% sure it’s a POR-15 tank liner, silver grey, hard finish, will not dissolve in Acetone.
a lot of the chemicals I would normally have tried are no longer legal for private sale, I would have put MEK (methyl Ethyl Keytone) in the tank with a handful of nuts and after a day or so of shaking and soaking, I would have poured out a grey slime ball and stared the liner process over.
so the question is how to remove a failed POR-15 tank liner? Without using chemicals that are not readily available, and I can not find a radiator shop that does hot tanking any more.
any sugestions?
I've never personally lined a tank myself so I'm only familiar with what I read here, but many have used acetone to remove old tank liners.
I believe it may be true that acetone alone is insufficient to remove a cured POR-15 liner. Without harsher chemicals, you may need to rely on abrasive removal. Screws, nuts, tumbler. Or possibly media/vapor blasting. If you also need to protect the exterior finish, that could be tricky.
MEK is a desired source on the commercial side is what to look for in your area. An aircraft retro repair and testing outfit outfit is a good candidate for a freelance worker willing to do the job and dispose of those chemicals correctly.
Forget the outer gas tank paint finish that is a memory! A full repaint is needed.
Cutting out the inner liner of the tank open and blasting it out. Then rewelding it back together is also a good option for a clean build and correct new liner application again.
Dominion Sure Seal Sure Strip with Methylene chloride, I buy from Global Autobody supply. Canada only.
And be prepared for price shock. Use a mask with proper filter and lots of protective gear. For the epoxy liner I took out it was a slow process but was effective.
It does sound like POR-15.
Contact the company and see what they recommend.
Thank you for the replies,
the Guy at POR-15 said to use a paint stripper with Methylene Chloride.
maybe this tank will become shelf art as a previously loved tanked in good condition with no liner is becoming more attractive.
and if a new liner is needed, Kreem can be removed with acetone.
Is your liner actually peeling off in chunks and you are concerned that enough is sloughing off it will plug your petcock filter and (added) fuel filters? Because aggressive use of chemicals and/or "mechanical" removal may make Swiss cheese out of a tank for which there is plenty of life availabe otherwise, as you are learning, and I have learned the hard way
I have had great luck with electrolysis...a little washing soda and a battery charger, leaves the tank in great condition and no further work necessary, no liners etc.
Caveat: I only care about riders, how the tank looks inside is of no concern to me and I know that's not for everyone. I did use Caswell Coatings once and it worked great, haven't hear about it peeling like the other products
The liner is flaking off in 1/2 inch chucks in places, what I can see is there is some rust underneath. I tried to attach a picture but it’s was huge :)
so before I spend money on this tank or another I going to throw some hot soapy water and nuts and bolts in there, see what I can knock loose, then hit it with a pressure washer, then de-rust with some vinegar and see where that leaves me. Looks do not matter, but leak free and no chucks clogging the fuel lines is what I am going for. Working first, pretty later.
You can downsize pictures right on most phones now, and the limit for pictures is 5 Mb here so it could still be more than large enough to zoom in on. If you're working from a computer you can use Paint (or the Mac equivalent, if you're using one) to resize pics too.
Got a few possible scenarios.
a. Clean out the inside as best I can which what I have, cheap sandblaster, pressure washer and elbow grease, and recote the inside.
b. Buy a used tank of eBay, $600 cdn
c. Buy a new tank of eBay from Thailand, $600 cdn
d. Buy a new CG125 tank from Amazon $150 cdn.
The liner looks pretty intact with a bit of flaking on the bottom. If it was my tank, I would use it as is and periodically check the sediment bowl for any debris, unless of course there is a lot more flaking and rust that we don't see. If more rust in the bottom, I would leave the liner alone and treat the rust.
a. Clean out the inside as best I can which what I have, cheap sandblaster, pressure washer and elbow grease, and recode the inside.
If that is the worst there is then keep a look out as noted for debris and now move on, as that is a pretty intact liner there in that pic. ;)
Good to know for the good stuff still. (y)
Forget the vinegar and find a janitorial supply that sells this or something similar. Not only will it remove the rust etc but leave a coating on the steel that prevents rust.
Find an old electric/gas stove on Craigslist for cheap and use the oven to burn out the liner.
It does look like they coated over some rust which is the mistake too many people make with liners.
Yep. I've used POR15 for decades with never any issues and tanks still going strong. But if the tank isn't prepped properly, according to the letter of the instructions, they can fail...
If you're going to run it, you could add an inline filter. Some people swear by them, some people hate them. I don't always use them on my bikes -- most petcocks do have a strainer -- but a filter just saved me from having to clean 4 carbs on a 350F a couple months ago (from a tank that I lined with POR15). It didn't fail, it's holding up fine, but it had some dust and whatever that the filter picked up and started causing fuel starvation issues. Popped off the filter, put a new one in, and I was down the road without the hassle cleaning those four carbs.
"Forget the vinegar and find a janitorial supply that sells this or something similar. Not only will it remove the rust etc but leave a coating on the steel that prevents rust."
I"ve used something similar: brick cleaner (phosphoric acid) from Home Depot on rusty bolts. It removes the rust and leaves a gray coating. Never tried it inside a tank though.
I've seen you do this a few times - if you click the "Reply" button right under the post you want to quote, it comes out with the post quoted (and your reply below it) like this. (y)
I plan to use it on my newly-chromed (but rusty interior) brand new gas tank I bought for my 450 restomod that was freshly chromed earlier this year, then hurriedly packed to ship back to me without first drying the inside of the tank so I received it back with beautiful chrome outside and the brand new tank interior rusted. I've already tested it on a lower engine case that had some aluminum corrosion and a rusty windage tray, and it worked just as described. And it rinses off easily with water.
So an update, I stripped the paint of the tank, found a few holes that had had been jb welded, so I guess I know why the tank has a liner, cleaned it all up to bare steel removed the expoy patch, soldered the holes up and leak tested over night, no leaks, except for the filler cap seal. Tank is now sitting with vinegar and drywall screws, it’s getting a five minute shake and turn every hour or so.
In a day or four once the rust is out and with luck the larger chunks of the failed liner a quick rinse with water and baking soda then a forced dry (rinse with acetone, or isopropyl alcohol depends what I have) a coat of fogging oil to stop rust and that will be it for the inside, a quick coat of self etching primer on the outside and I can shelve the tank and work on other issues and come back to it later, no rust, no leaks, no issues, I’ll drop a inline filter to the carb and monitor when riding which is some time away, but should be good.
now as for the outside I was going to paint but I am thinking at trying my hand at a warp, but that’s a future project.
Forget the vinegar and get one of the Phosphoric Acid washes for your tanks interior. It will eat rust easily and leave a phosphoric coating inside that won't flash rust when washed out with hot water and blown dry with hot air.
Joe just relined an old gas tank after various repairs on the metal of the tank bottom. The old liner was pretty intact, yet just too thin and going through in some areas.
