Tool for opening wiring multi plugs
Windmill John
East Sussex, England
In the past, I might have used a tiny screwdriver or the like to remove a wire from a multi plug. But, if I want to start pulling apart more multi plugs, are there recommended by you guys, little tools or tips to make it easier?
Also, links to decent Japanese bullet connectors. I am in the UK, so I guess vehicle wiring products will be the shop for connectors.
Cheers
I use a harbor freight metal pick and it gets the job done for most connectors I've come across on Hondas and other. Recently I took apart an extremely complicated harness (Harley bagger with radio and all the add ons) to scavenge the wires and connectors and all I used was the metal pick and a small screw driver
The tool shared by fxray in the link I posted above is nice because it also works with different sizes of round connectors, like the key switch plug for the 350/450, in addition to the rectangular block connectors.
I had used a flat blade screwdriver prior and felt that sometimes that involved a bit of unnecessary gouging or distorting of the plastic.
