Jays100
This is a multi-part series on a new design oil pump for the 450 & 500T's. Stay tuned, its a fun read, gives some insight into my quirky self and ultimately reveals a new, improved and superior Oil Pump that will bolt-in to your DOHC twin!
Part 1, Discovery
When I first encountered the small Honda twins, I was a young man and the local Honda shop had a SL175 on the showroom. I think this was 1970-ish? Later, a science teacher had a CL450 that I really, really liked. Then, nothing, (well, a lot of history in this gap but no ownership) until relatively recently when a 71 CB450 turned up on Craigslist with a parts bike in the photo background - I jumped on it hard. The background bike was a 95% complete ’68 CL450 in pretty rough shape, lots of rust, engine stuck but the front fender, pipes, tank, side covers and instruments were all there. It had 29K miles on the clock.
A complete rebuild ensued, the usual suspects were replaced, repaired, repainted. In my research, an upgrade was to replace the 16mm piston with a cast iron housing oil pump with one from a 71 and later model with a 19mm piston and aluminum housing. I was surprised that the cam followers on the exhaust side were worn out, as was the cam, all replaced. I now wish I had saved all those bits, instead, they were thrown away.
Without knowing it, the germ of an idea was planted at that time – those parts shouldn’t be worn out, there’s gotta be a better way!
Worn parts from a DOHC 450:
I didn’t have a photo of my exact worn parts but did find this from another never-to-be-mentioned site. Photo attribution is marked and I have purloined it accordingly. Anyway, it’s a common problem, you may have personal experience!
All worn part arrows point to a root cause failure due to high wear. This is either too high contact pressures or more likely, lack of oil lubrication in those critical areas. Specifically, the exhaust cam bearings, followers, lobes, literally every moving part in the top front of the engine.
Part 1, Discovery
