Stl360, cleaning under oil wind tray.
I think it is definitely worth the effort to remove the oil wind tray and properly clean the accumulated sludge from underneath.
I tried several methods to clean mine out before I decided to remove the tray. Glad I did as it was “ cruddy” under there.
I wrote a thread on what did here at VHT but I can’t find it. Trying to blast it out from the sides may just loosen some of it to later get mixed in with circulating oil. There is only one stand off that is limited for access when taping but easily enough done 1/4 turn at a time when taping. Also you will be able to deal with the rust shown on the top of your tray. Pound to a pinch it is also rusty underneath. I recall I used 6mm domed machine screws, Allen heads. You need to make sure enough clearance under one of the flywheels.cheers
I may take a peek with the endoscope later, too, that's a good idea.
Perfect. I haven't watched the video recently and wasn't tuned in on that detail at the time. Very relevant now, so I should rewatch. I hadn't wanted to disturb the screw, but it's staked, so I shouldn't have worried about that. Much easier than what I was doing.
I thought I was having trouble finding neutral until it dawned on me that both shafts were moving because there was enough oil adhesion on the free gears to transfer motion from the main shaft to the countershaft. When I held the free gears it was obvious that it was in neutral. So, everything seems to be in good shape.[/QUOTE]
